My TM 45mm. Sticky Oily stuff inside?!
The 45mm has a rubber gasket of sorts on the side of the slide, and when using ALKY it gets dryed out and causes the slide to stick(from lack of lubrication), so I open up the top of the carb,and use alittle oil the soften the gasket up,for smooth slide action, but it does cause a black reside on the slide.
I am not sure if this is what your seeing but .....THER YA GO!!!
Biggerisbetter.
Biggerisbetter.
