Dead battery
Old Apr 7, 2003 | 05:46 PM
DirtDemond's Avatar
Default Dead battery
I once read that the ignition on the ds has a fuse somwhere could that be the reason why my batterie keeps going dead. i can ride it all day and nothing goes wrong but after a day or two of sitting in the garage the batterie goes dead. i have never had a problem like this. and where is the fuse located.
Old Apr 7, 2003 | 06:03 PM
DSDuneCrazy's Avatar
A fuse wouldn't have anything to do with your battery discharging while it's parked in the garage. It sounds like you have a low current draw somewhere in your electircal system.
do a search on the forum for "battery", you should find alot of posts about it.
Old Apr 9, 2003 | 12:52 AM
macmc443's Avatar
I had the same problem with 2003 DS650 BAJA and i brought it back to the dealer and it was a loose conection from shipping.At least thats what they told me.
Old Apr 9, 2003 | 01:32 AM
JSsDS's Avatar
The fuses are under your seat on either side of the air cleaner box. They look like weather tite plugs.
As DSDC said they will have nothing to do with the battery going dead. You could just have a bad battery.
charge it at 2 amps for 4-6 hours and remove the negative cable for a few days. If it still goes dead its your battery.
Let us know what you found
Old Apr 9, 2003 | 12:33 PM
DirtDemond's Avatar
i will try that i did add some excessories so that could be the problem i put piaa lights where the baja lights go on the ds baja they look pretty good and i am always the leader of the pack on night rides in florence and winchester bay for the light. thanx
slowgsxr97
Mar 18, 2022 03:40 AM
scram5050
Sep 3, 2015 05:06 PM
cody500ho
14
Aug 14, 2015 05:03 PM
Hondamx751
Aug 13, 2015 01:06 AM
ScopeZ_
Jul 28, 2015 01:44 AM
