how do i adjust the clutch?
Old Apr 16, 2003 | 06:57 PM
brad650's Avatar
Default how do i adjust the clutch?
i noticed you can adjust the clutch on the side of the case. what is the correct way to do this? [img]i/expressions/face-icon-small-smile.gif[/img]
Old Apr 16, 2003 | 10:42 PM
Eaglecollector's Avatar
Well the measurment you want between the arm that hold the end of the clutch cable and the bracket that acts as a stop is 2 5/8" to 3"
To get make an adjustment. There is a rubber boot over the cable just to the left of the cable stop. Slide that back out of the way. This will expose the adjusting nut.
Up on the bars where your clutch lever is, is another adjustment. This one is for cable free play. The book says about a 16th of an inch. I go with as much as an 8th on mine.
Hope I made sence [img]i/expressions/face-icon-small-smile.gif[/img]
Old Apr 16, 2003 | 11:43 PM
brad650's Avatar
my clutch is slipping a little, so i think it just needs to be adjusted so what way do I adjust that nut?
Old Apr 17, 2003 | 03:09 AM
Hightower's Avatar
turn it to achieve free play in the lever. amount of freepay is not critical, as long as you have some. define freeplay as slack - cable must have slack to be certain clutch is fully engaged.
ghost civic
Jan 15, 2020 07:43 AM
DanP24
1) Engine problems..
Aug 13, 2015 09:14 PM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
ghost civic
Jul 15, 2015 10:48 PM
200es
Jul 10, 2015 09:09 AM
