Piston & cams?
Old May 1, 2003 | 04:52 PM
JMAC650's Avatar
Default Piston & cams?
What do you guys recommend for piston & cams for my 02 baja? I want to keep it reliable yet give a little more kick. Also I run race fuel so compression is not an issue. And I also want to keep the stock carb.
Old May 1, 2003 | 05:59 PM
biggerisbetter's Avatar
RON WOODS!!
ask him if he has come out with a 12:5 piston yet.
Biggerisbetter.
Old May 1, 2003 | 09:11 PM
SANDMAN430's Avatar
ron woods it is a easy bolt together, i ran the stock carb for a while and was very pleased, i'm getting the 45 better tuned but it just seemed snappier with the 42. plus there easy to work with. i know dsmike gets great things out of his woods products, and from reading these forums no one seems to see problem later down the road
Old May 1, 2003 | 11:49 PM
JMAC650's Avatar
What do you guys think of the kit that Alba Action has? It's a JE piston and Web cams. It claims 5 hp at the rear wheels.
Old May 2, 2003 | 02:03 AM
SANDMAN430's Avatar
is it cheaper than woods?
Old May 2, 2003 | 05:00 AM
JMAC650's Avatar
It's $949 for piston, cams, springs, & retainers. Not sure on the ron woods.
Old May 2, 2003 | 12:24 PM
ThePunisher's Avatar
You can get the same kit from TVI including new clutch springs which you are going to need for that much!
Old May 2, 2003 | 12:39 PM
1BigDSRider's Avatar
Heard that Tvi and sam coe were having problems with gaskets sealing. Was that true?
Old May 2, 2003 | 01:04 PM
SANDMAN430's Avatar
i don't think tvi has problems with heads sealing gary has put a lot of work into sealing the head i think he is the one that started the o-ring on the ds to seal the head, plus he has stronger head bolts. he is another good place i think you could get a j&e piston and web cams from gary and be less than 900, if you check some guys have a few left over parts also
Old May 2, 2003 | 04:13 PM
BIGBAJA's Avatar
The price for the Alba kit includes a $275.00 core on the cams.
