** Dialing in my 45 **
Old Jun 12, 2003 | 04:30 PM
  #21
TyreSpinner's Avatar
Default ** Dialing in my 45 **
I thought I would bring up this thread again.
It seems I am still running rich according to the plugs.
Stage 1 DS @ Sea Level with K&N in box with lid ON.
The plugs are still very sooty and the middle part is chocolate brown.
I fixed a needle valve leak, but perhaps it's leaking again...dunno
150 main, 40 pilot, 96 needle on 2nd clip from top.
Running a Tm45.
What NOW???
Old Jun 14, 2003 | 12:24 AM
  #22
chop's Avatar
you guys are going to freek but im running 170 main 97 needle in the 2nd from the top and get this,a 27.5 pilot w/accelarator working.dont ask me how it works but it does because i have a set of new set of barnett clutches to go in it to prove it.i also had a dead spot from an idle to wide open punch,but thats history or at least it was the last time i rode it.the pump cured the dead spot on mine.so far im really pleased with the performance.i dont even use the choke,i just bump the throttle a little and she fires right up.btw,dont play with the throttle when the bike isnt runnig it will flood it.i found out the hard way.every time you push the throttle the pump puts a stream into the carb and it just sits there until you start it .just a reminder.good luck.
STLyamwar
Jul 25, 2020 04:44 AM
polarisrider1203
Aug 29, 2015 07:52 PM
Mphillips
Jun 26, 2015 03:52 PM
coolhuh
Jun 24, 2002 04:05 PM
sparkys
Jan 30, 2002 10:31 AM
