help from anyone at raceway
Old Feb 1, 2006 | 10:21 PM
Agu01's Avatar
Default help from anyone at raceway
1st I purchased an atv from an unauthorized dealer, I think its a 2004 Yamoto Atv110. Where is the Vin for verification? The certificate of origin is from Winspeed Ind. Inc. 2nd I found this out trying to get it repaired by them. The atv runs and performs well for 15-20 mins., after this point from an idle with a slow acceleration of the throttle the atv bogs down. If you make it past that point, it will run fine at a high rpm. Checked the gas cap seems vented ok. Also trying to verify cert. is correct so I can order parts if needed.
Old Feb 2, 2006 | 09:57 AM
RacewayATV's Avatar
Give us a call after 3pm Est. and we will see if we can help you out.
Mini ATV Raceway ATV
Old Feb 2, 2006 | 10:15 AM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Welcome to the forum Agu01, Winspeed was the Yamoto importer for a while and may still be so its highly possible that you have a Yamoto. Have you ever cleaned the carb? VIN should be stamped on the front horizontal bar across the front of the machine. WINXCGZH is the first 8 letter in my wifes yamoto's vin. Also you cant go wrong asking John at Raceway for help. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Feb 2, 2006 | 08:56 PM
Agu01's Avatar
Thanks mywifesquad, my first 7 are winchz, still didn't find on bike. No didn't attempt carb, did not know how to adjust it after. Did drain bowl. Found directions on here last night on adjusting, will attempt this weekend
Old Feb 2, 2006 | 09:02 PM
Agu01's Avatar
Raceway , I will call for help, thanks for being a generous dealer. I'm in central time zone so I am an hour behind. Whats the latest you take calls after 3pm until? I will be looking to purchase a new rear fender.
Old Feb 3, 2006 | 09:54 AM
RacewayATV's Avatar
5:30- 6:00 PM Est.
Old Feb 4, 2006 | 06:13 PM
Agu01's Avatar
Took carb apart and cleaned. It was very clean already. Tried all notches on the needle, fouled a couple of plugs doing so. The carb was actually tuned in perfect before I took it apart and readjusted it. Same thing happens, atv runs fine idle and acceleraing 15-20min. when the engine is good and warm it bogs down accelerating from an idle, will run fine at a higher rpm. Are these enginesjust not made to run long? What is recommended riding time before allowing engine to cool? Or is there any known problems with the coil overheating on these atvs?
Old Feb 4, 2006 | 06:26 PM
smb05's Avatar
Did your ATV come with a in-line fuel filter? If not take the fuel line off and check for any obstructions in it. Some of the fuel tanks will have little black plastic flakes that will get into the fuel filters and fuel lines and clog them up. Check that first. Before you start on the electrical components.
Good Luck
SB.
Old Feb 4, 2006 | 07:22 PM
Agu01's Avatar
Thanks for the advice symb05. No it doesn't have a fuel filter, the very first time it had these symptoms, I drained the tank thinking it could have had water. Anyhow took the advice and checked the fuel line, it was clear.
Old Feb 9, 2006 | 06:42 AM
kamakaze's Avatar
my 150 is doin the same thing..bogging out when u go slow and push the throttle in.and ive had it for awhile and it still does it.
