blue wire and green wire?
Old 04-26-2007, 12:40 AM
mykool61679's Avatar
Default blue wire and green wire?
my son has the mini-utility 110, and to day it stopped running mid-way through a ride, it was trying to start(turning over) just wouldnt get going. i pushed it off the trail took a five minuite brake and it started and ran fine all the way back to the trailer. when i got back i noticed that a green wire and a blue wire was unplugged/ripped out of something. it is located under the left rear fender by the battery. could this be for the safety swith or what. taped up the wires and all seems wel. my question is what are those wires for and should i repair them or is it going to be fine. i dont want to have a safety issue for my son(who is 6) out in the middle of the trails, nor do i want to get stranded. any help would be appriciated, thanks mykool!!!
Old 04-26-2007, 07:18 PM
come on, i need some input here. its the mini-utility from raceway. please help.
Old 04-29-2007, 01:04 AM
jamlew33's Avatar
I will check..My son has the same quad..I have replaced alot of stuff
plus re-wired the fuse holder into the battery area..I dont have the
quad at my house at this time..It may be to the kill switch i cant
remember...You need to use better wire terminal's going to the
battery.They will break do to the movement..I'll try to look
for you...
jeepwheelin02
1) Engine problems..
07-18-2020 06:42 PM
400H0
10
08-20-2015 07:34 PM
toonces
08-05-2015 05:55 PM
ScopeZ_
07-28-2015 01:44 AM
carolinabomb
07-26-2015 08:40 AM
Quick Reply: blue wire and green wire?
