Electric Choke Question
Old 06-25-2007, 05:31 AM
bakermon's Avatar
Default Electric Choke Question
tichigin,
The choke and everything electric on the bike is 12 volts. I tested mine with a 12 volt converter I had just so I could see how it works. If your choke was to be stuck out you would have trouble starting cause it would be cutting off the extra gas needed to get going. I'm not a big fan of those carbs and had similar problems last year John at raceway got me a mikuni carb for mine and never had a problem since. I think the electric choke has a bad rap when it is really the carb. I don't know why the voltage is so low on your test but it has to be 12 volts. FYI- I had bought some small drill bits to test the jets on an off road golf cart I own and at the same time did some test on the old kazuma carb I had. Even though the main jet was stamped a 96 the drills showed it was barelly a 90 jet. I think the quality is not there. For tons of help try oregonvintage.com
Old 06-22-2018, 08:34 PM
Coyotedogg's Avatar
Default electric choke
just put my carb back on a chinese atv...went to try and start it and the electric choke makes a buzzing noise and thats it what did i do wrong does it go in a certain way??
Old 06-23-2018, 04:14 AM
The electric part of the choke is a heater coil so how it comes to be buzzing I can't imagine. Are you sure it isn't your starter solenoid buzzing, due to either a bad connection, flat battery, or seized engine?
Old 06-23-2018, 10:37 AM
Coyotedogg's Avatar
i cant imagine the engine is seized it was working almost starting but not quite so i cleaned the carb a bit....and ya its deffinetly comming from the choke when i hit the ignition i can feel it vibrating and heating up will put a diff battery on and see if that makes a difference tho..
  #15
Old 06-24-2018, 01:41 AM
The choke shouldn't get any electricity until the engine is running, as it gets it's power direct from the alternator (AC), I think you must have wired it wrongly. Some may work differently, but most are based on the Honda alternator driven design.
  #16
Old 06-24-2018, 10:24 AM
Coyotedogg's Avatar
well
a different battery worked it turns over still wont start damn thing.
mdigitale
08-06-2015 12:35 AM
binky79
07-30-2015 06:37 PM
raceware
07-30-2015 06:59 AM
cornermike
07-30-2015 06:37 AM
ghost civic
07-27-2015 03:15 AM
Quick Reply: Electric Choke Question
