jetmoto 110
Old Jul 4, 2007 | 10:22 PM
jrwhitey_2000's Avatar
Default jetmoto 110
I recently purchased a jetmoto 110st-l for my son. I am having trouble getting the toe correct on the front end. I need a good picture of the front end of one of these to see how the tie rods are installed correctly. The ball joints seem to be on excessive angles also.
Old Jul 5, 2007 | 03:03 AM
pimpsmurf's Avatar
Default jetmoto 110
Measure from the very front of each front wheel, and the very back of each front wheel. You do this while your son is sitting on the quad, and you have stepped on the front to compress the suspension and then let off. This will get it to about the right ride height to measure toe-in. Then you compare the two measurments to see the difference. They should be VERY close to the same and toed in just a tiny bit (maybe 1/4-1/2" difference between the two measurments.)
Does that make sence?
To do the camper (how much they lean in twards the middle of the quad) you just need to eyeball. They should be leaned in just a little. Maybe 1/2-1" difference between measurments from the top of the left front to the top of the right front, and the bottoms the same way.
Let me know if I'm making sence of not. I'm extremely tired.
-JNY
Old Jul 12, 2007 | 09:35 PM
snubs's Avatar
Default jetmoto 110
Can someone please tell me how to post a new topic.
Old Jul 12, 2007 | 10:22 PM
LTZ's Avatar
LTZ
Default jetmoto 110
<div class="FTQUOTE"><begin quote>Originally posted by: snubs
Can someone please tell me how to post a new topic.</end quote></div>
First click on the forum area you wish to post your topic in. Then about half way up in the middle you'll see where it says new topic. Click on that and fill in the areas with your post title and the message area with your question or topic.
To answer your email I am one of the moderators on this site. You can reconize us by the title "Quad Patrol" under our user names to the left.
Welcome to the forums!!!
RacewayATV
1) Engine problems..
253
Feb 7, 2013 10:06 PM
mywifesquad
Apr 19, 2007 04:15 PM
jkylnhyde
Aug 25, 2006 12:25 PM
toshkitty
Aug 16, 2006 09:14 AM
socaltoyman
Aug 4, 2006 07:56 PM
