valve ajustments
Old Sep 8, 2007 | 02:13 PM
jetmotoracer's Avatar
Default valve ajustments
what are the valvs suposed to be set at ??????... and what happens if there a little off
Old Sep 10, 2007 | 11:27 AM
billl2099's Avatar
i see you had 28 hits on your question and nobody but me i guess can answer it, your valves should be set at .004 intake, .006 exhaust cold. what happens where there off a little, it effects the valve timing, this means if the valves are set a little loose the camshaft needs to rotate a degree or two before the valve starts to open which translate into a little loss of power and valve noise, a clicking sound, if the valves are set to tight, the camshaft starts to open the valve up sooner than it's surpose to, also having a tight valve can cause a valve to burn, also can make the engine hard starting because the valve may not be fully closed letting out compession, the valves are set when the engine cold, this is because metal expands when warm, it's better to set the valves up loose than tight, the little bit of power if any you loose will not be noticed, hope this aswer question,
Scooter's Shop
23
Oct 22, 2015 07:04 PM
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 28, 2015 10:02 PM
2many2ride
Sep 27, 2015 04:35 AM
maveikfe
1) Engine problems..
Sep 24, 2015 10:36 PM
