Rear Sprocket Info Needed for JM110 & JM125
Has anyone found a replacement for the Rear Sprocket on a Jetmoto 110 or Jetmoto 125 ??
I have searched all the JTSprocket Engineering Drawings and info at Sprocket Specialists, without any success.
Does anyone know what this six bolt, small diameter mounting pattern was copied from ?? (or is this a "one only" Chinese design ? ).
OR, in the absence of this info; Does anyone know of a Sprocket Hub change that will fit this axle (spline pattern & diameter), that gives more readily available sprockets of different numbers of teeth.
I already have the front sprocket info and want to go down to a 13 on the front, but also want to go to a 46 to 50 tooth rear sprocket. This is because I want to install 20 x 11 - 10 rear tires and wheels (like a JM250) for more rock clearance.
Any information would be greatly appreciated - Thanks
NJDale,
just PM'd you the info I had -- sorry for the delay.
the 46 I have has the 6 holes to match up to the JM mounting plate. Thought of looking at some other 4 hole sprockets and seeing if they'd match up to the plate.
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
jrooker6
Ask the Editor
11
Apr 21, 2016 07:35 PM
