yamoto 50 draining battery
Old Jul 1, 2009 | 05:57 PM
bigbucks4me's Avatar
Default yamoto 50 draining battery
Ihave a yamoto 50 the problem im haveing is the battery is being drained dead i put a new battery in it but thats dead now too any help would be much appreciated
Old Jul 1, 2009 | 06:05 PM
split196's Avatar
how long is it taking to drain ?
Old Jul 1, 2009 | 09:04 PM
Default draining bat.
almost overnite
Old Jul 1, 2009 | 11:16 PM
LynnEdwards's Avatar
Electrical Expert
First thing to determine:
Is the battery not being charged while the engine is running, or is the battery being drained after the engine is turned off. And I guess we also have to consider the possibility that both problems are true.
When the engine is running at a medium to medium fast clip measure the DC voltage right at the battery terminals with all accessories such as head lights turned off. It should read 13.5 to 14.5 volts. If it does then your charging system is working. If it reads less than 12.6 volts then your charging system is not working.
To see if the battery is being drained after the engine is turned off, pop out the main fuse. Insert a current meter on the 10 amp scale (most meters have a current measurement setting) in place of the fuse. It should read zero. If it does then try going to a lower scale such as 500 milliamps (0.5 amps). It should still read zero.
Leave the fuse out overnight. If you read zero current drain with your meter earlier, and the battery still goes dead overnight then the battery is bad.
Old Jul 5, 2009 | 08:30 AM
when the engine is running its only about 8.2 what do i check as far as a charging system
Polarisman1123
Sep 13, 2015 10:06 AM
Ronbo6270
Aug 6, 2015 11:54 PM
momma's bike
Aug 6, 2015 09:49 AM
Shifts
Jul 3, 2015 07:59 AM
