GIO 200CC Gears wont enagage..
Old Aug 1, 2009 | 03:25 PM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
This is a conversation rawfish and I had in the pm system..I thought the video's and info would be a good thing in the open forum. rawfish agreed and so I copied it and posted it..
Quote:
Originally Posted by rawfish
Hi there,
Any idea what its suppose to look like in there? I have it opened but I dont really know what I am looking at ... I can send you a pic if you are willing to have a look c?
Thanks, Roy
Quote:
Originally Posted by mywifesquad
Hi,Roy
Your gonna see the clutch basket and a couple of gears...down in the lower left area will be where the shift shaft comes thru...its gonna have a sort of steel arm on it with a couple of hooks that sort of form a U shape..They pull back and forth on the shift drum to change the gears..That part will most likely be under the clutch basket and the clutch basket will have to be removed to replace the arm if its broken..You should be able to look behind it to see if the arm is moving the drum with out removing the basket. Ill look at pics for you and tell you what I think..
Your Welcome, Joel
Hi Joel,
I appreciate your taking the time to respond and have a look at these pics and videos. I have posted them to our website for you to have a look at.
Video
Almost millertime :?]
Thanks
Roy
In the 2nd video at the beginning it looks to me like the shift drum isnt turning...From that Id think the hooks on the shift arm are worn and not turning the drum and engaging the gears... Could you look real close at the drum when you shift the gears and see if it rerally isnt moving?
Joel
Old Aug 2, 2009 | 10:04 AM
rawfish's Avatar
Default Do you see the drum in this image?
Hi there,
If so can you tell me by letter reference that would be sooo helpful :?]
Video
Thx.
Old Aug 2, 2009 | 08:15 PM
KTM Patrol
Former Chinese POW!
Its the thing "C" is turning... sort of a star like wheel looking thing
Old Aug 3, 2009 | 11:52 PM
Sawyer's Avatar
Rawfish you might want to track down a clymer repair manual of that covers that engine. I assume its based on an older honda engine. I know many of the 50cc to 150cc engines the clymer repair manuals guys say come in real handy. A book with pictures and a blow up of parts and stuff would probably make things easier etc.
1982 Honda ATV Repair, Service, and Maintenance Manuals
patrick.oc123
Sep 16, 2015 03:45 AM
patrick.oc123
Sep 15, 2015 02:45 PM
bigbear350quad
Sep 11, 2015 12:40 PM
John Reed
Sep 9, 2015 03:46 AM
awer1968
Sep 8, 2015 11:02 AM
