No compression
I got the wiring straightened out (thanks to LynnEdwards). Now I have another problem know compression. The valves seem to be working right. I was thinking the rings are bad. Any ideas it is a vbike 250 v4s. Thanks, David
A bent valve would certainly lower compression.. Good deal getting it fixed...Where did you get the valve? or did you straighten the bent one? Did you do all the work yourself?
I got all my patrs at Chinese ATV Parts, Kazuma ATV Parts, Sunl ATV Parts, Roketa ATV Parts, BMX ATV Parts! good guy to work with. He hooked me right up. I replaced the head gasket and the one on bottom ot the jug. Also replaced the rings sence I was that close. Got $200 in the whole thing including buying it and getting a new battery.
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
Steeldon
Sep 9, 2015 09:38 AM
