Linhai Wrangler 330cc 4x2
Here is a service manual for the 260 look it over as it has pictures and see if its your machine. If so your in luck (download it) as it looks like a good manual and will give your service info. http://www.bdj-imports.com/downloads...p%20manual.pdf
This is the website that has them all, one service manual for a 250/300 water cooled CVT trans is really good http://www.bdj-imports.com/downloads...r.asp?login=ok
I really appreciate it fellas. I use dogpile as a search engine and it didn't come anywhere close to finding anything like that which is surprising because I thought it searched through google as well, but yall were a major help nonetheless! The manual claims only 1.5 quarts of oil fill?!? Does that sound normal??
To be sure on oil fill, put in the recommended amount,then run it to circulate the oil, then let it sit about 5 min, then check the dipstick, don't thread it in, just push it in to until it stops on top of the threads, then check the level,then add if it needs, and make note of the total amount used. I checked that online manual, I guessed right, it does have an oil screen instead of a filter, but the bottom drain plug/screen is exactly like my Yamaha Wolverine,with the spring and cup shaped strainer.
Impalaman
1) Engine problems..
12
11-08-2015 07:17 AM
