starting issues
Old Jan 17, 2010 | 01:57 PM
drknute3's Avatar
The carb looks like the one posted by Geoff, but doesnt have the flat headed screw to the right of the spring loaded one. The spring loaded screw is the only one. I can adjust it all the way in and just raises idle without bogging so I assume it is set screw for idle speed. The a/f must be internal?
Sawyer, when I would crank it until the battery died, I pulled the plug and it was wet with gas, but we were giving it throttle as we were trying to start it. This is our first non EFI vehicle so we were kind of in the dark. Since I cleaned the carb and changed the plug, I have have'nt had any starting issues this winter. I start it by choking it and turning it over...no throttle. Then slowly open the choke as it warms up and stays at idle. So far, so good. Hopefully this summer the unit will continue to run well. Do you think since it starts so easy in the cold that any adjustments should be made so that it will continur to start easy in the summer?
I also have a second question about changing the oil. On the bottom of the engine I see two possible bolts that could be the oil drain. The other 4 bolts mount the engine to the frame. One the bolts sits parallel to the ground and the other is angled. Which one do you suppose is the oil drain? Also do the engine and transmission share oil? Meaning I only have to change the engine oil and the tranny will get changed as well? What is the oil capacity of one of these 110cc engines?
Alot of extra questions I know, but I appreciate the help
Old Jan 17, 2010 | 02:13 PM
drknute3's Avatar
The bottom of my engine looks just like the pics posted by onetencc in his post about oil plug location. Didnt see his post there... So which one is it?
Old Jan 17, 2010 | 07:29 PM
nimadd's Avatar
The plug on the left in OneTenCC's picture is the oil drain. By the way welcome to the forum.
chinkapin
Jul 14, 2016 06:58 AM
buckshit
Sep 24, 2015 08:49 PM
BEEFKING69
Jun 17, 2015 12:38 AM
Steven Bandemer
Jun 9, 2015 08:50 PM
1000gade
May 27, 2015 12:37 PM
