Proofreading new wire harness.
Old Jan 24, 2016 | 03:28 AM
Drawing 3 doesn't look to have the choke wired right. If it is an automatic choke, this is how they usually work. The choke normally allows excess fuel through, but when you start the engine, a wire from the stator (white or yellow) feeds AC power through a heater coil in the choke. As the choke warms up, a thermostat closes the excess fuel valve. Once the engine stops, the heater coil begins to cool, so opening the excess fuel valve again.
Old Jan 24, 2016 | 03:43 AM
Unsub's Avatar
Hmm. Since its ac, how do i go about connecting it? I traced the choke in my old harness and it was also there connected to the ignition
Should then the positive go to yellow stator and negative to ground or am i far off here?
Old Jan 25, 2016 | 03:45 AM
If it works, it may be best to leave it, you will have to start up as soon as you switch on, as the choke will start to "switch off," and be sure to switch the ignition off when leaving the machine or the choke will be getting power, flattening the battery and overheating the choke.
Old Jan 25, 2016 | 10:04 AM
Unsub's Avatar
It does work fine, it's a bit hard to start as the battery is bad (need to replace it) and it doesn't seem to get fuel (plug is dry). So I've had to use jumper cables from a car battery and pouring some fuel into the sylinder to start it, as soon as it's started and is getting warm it runs really fine.
I'd suppose this would be a carb problem and not related to the choke? But I'm fairly novise in this so not sure.
Old Jan 26, 2016 | 03:57 AM
  #15
It sounds like a choke issue. I did hear of "manual choke conversion kits" for these carbs but don't know if you can still get them, or where from.
Pooldawg
Jan 1, 2017 11:18 AM
Samantha Brown
Nov 17, 2015 02:44 AM
joe2k
Nov 14, 2015 05:53 AM
scottbrockwell
Ask the Editor
Nov 9, 2015 01:21 AM
Thatguy23
1) Engine problems..
Nov 3, 2015 03:10 AM
