carb ?
Old Mar 23, 2016 | 07:32 AM
grapejuice420's Avatar
Fresh gas there is deft fuel flowing to the carb I'm just not sure how much should be coming thru should the whole line be full of fuel pouring out or as long as its flowing is it good
Old Mar 28, 2016 | 10:39 PM
blaze_master's Avatar
get a new cdi for 6 dollars change the sprockets and new exhaust the jets might be too big and the thing is flooding out the sprocket change will help because it will move easier all these will help and work in unison and it will make riding more fun if it has the 14tooth front I recommend a 12 or 11 the top end will be less but the take off and torque will be amazing all this for less than $75 on amazon
Old Mar 29, 2016 | 08:04 AM
LT80's Avatar
LT80 Expert
"the jets might be too big and the thing is flooding out"
Funniest thing I've read.
Not to be fussy but a period and a comma now and then makes replies easy to read and understand.
Old Mar 29, 2016 | 09:15 AM
Default PC douche
take your English major somewhere else douche bag
Old Mar 29, 2016 | 10:46 AM
  #15
MPDano's Avatar
Originally Posted by blaze_master
Get a new cdi for 6 dollars. Change the sprockets and new exhaust. The jets might be too big and the thing is flooding out. The sprocket change will help because it will move easier all these will help and work in unison and it will make riding more fun.
If it has the 14tooth front I recommend a 12 or 11 the top end will be less but the take off and torque will be amazing all this for less than $75 on amazon
There you go
First thing first is to get it running correct stock. Then go with all these exhaust and gearing upgrades. Stock ATV's are fine for the normal rider. Beefing it up before fixing the underlying issue is not the best way to go.
Old Mar 29, 2016 | 08:44 PM
  #16
I ended up re adjusting the new carb the other day thing runs mint now deft fast enough for my kid right now thanks tho
Old Oct 26, 2017 | 06:48 PM
  #17
well opening up an old thread quad sat for a bit drained fuel tank fresh gas and oil now it doesnt want to run again i pulled carb cleaned it all out tonight will run great for like 30 sec then dies starts right back up but then will only idle push throttle and it dies im at a loss again any help would be awesome
Ckieffer29
Apr 1, 2016 04:49 PM
PleasantCrab
Apr 1, 2016 03:31 PM
hunter56
Mar 11, 2016 02:43 PM
tx-stephen
Mar 3, 2016 09:09 PM
