Zstar 110 - Replace Ignition/Kill switch with inline switch?
Old Apr 24, 2016 | 04:11 PM
AC-Greeny's Avatar
I put fuel in the tank and it leaked out of all sorts of vents and check valves (in the carb) that it shouldn't be leaking out of. The little gasket on the bowl is bad too.
So I'm going to order a carb and go from there.
Old May 2, 2016 | 10:08 AM
AC-Greeny's Avatar
Ok so the new carb came and I put that on.
I am still getting the same result. Cranks and cranks all day, but won't start.
I removed the CDI box to do some ohm tests and couldn't seem to get any resistance readings of any kind, so I think the CDI might be bad.
Old May 8, 2016 | 04:03 PM
AC-Greeny's Avatar
Finally got this thing running, so I will share my findings.
I was wrong about the CDI, the original was fine. (Zrock: it is AC-CDI, I was wrong about that too lol)
The carb was not properly diagnosed, I just replaced it. It's very possible that it would be fine with a good cleaning. The ATV sat for a couple years with P.O, so I just felt better installing a new one. Point being, there's no evidence showing that the carb was a contributor to the no-start.
Now, onto the things I did right.
1. Re-wire: I removed the whole wiring harness, did continuity tests on every circuit, and replaced wires where necessary. It was a mess, so I started with that knowing it needed attention.
The last 3 things I did before I had a successful start-and-run:
2. Tested Stator: found several opens, so I replaced it.
3. Tested Ignition Coil: did not pass resistance tests, replaced.
4. Set Valves: both timing and clearances were way off, set exhaust and intake to .004
I would also recommend the switch setup I have in the wiring diagram earlier in this thread. It works flawlessly and eliminates several components from the electrics that are known to be troublesome.
Anyway, hope this helps anyone with similar issues!
Green.
Traxter506
Jan 8, 2018 11:03 PM
Mekronid
Apr 24, 2016 09:08 AM
R.J.
2) Chassis problems..
11
Apr 16, 2016 04:27 PM
Jayb22
Apr 16, 2016 12:03 PM
misterddd
1) Engine problems..
Apr 15, 2016 10:25 AM
