Cqr fe250 extreme quad
See if you can find a makers plate on the frame, often this has the actual maker's name. failing that, the VIN number, in theory the makers name is coded into it. This doesn't always work with Chinese makers and you need a good VIN decoder, most on the net are rubbish. Motorcycle based decoders are best as a lot of obscure motorcycle makers also make quads.
