Tire size
Old Jun 23, 2004 | 06:57 AM
Kenji's Avatar
Default Tire size
atm the size of the rear tires on my warrior is 22x10-9. I'd like to put other tires on the same rim, like a 22x11-9. Is this possible?
Tx
Old Jun 24, 2004 | 10:31 AM
newbeatle's Avatar
Default Tire size
I think you can run those on a Warrior
Old Jun 29, 2004 | 02:12 PM
moldycheese's Avatar
Default Tire size
i ran a 22-12.5-9 on my warrior with no problems. just a little rubbing on my exaust at full travel
Old Jul 1, 2004 | 05:36 PM
Slacker1bob's Avatar
Default Tire size
Just about any tire will go on any wheel, as long as the wheel diameters match. going from a 10 inch wide, to a 11 inch wide, makes no difference. sometimes a 10 inch wide tire from one company is the same as a 11 from another. Remember, the tires do flex and bend, so they will fit.
Old Jul 1, 2004 | 07:27 PM
Kenji's Avatar
Default Tire size
OK, thanx ppl
Old Jul 4, 2004 | 11:46 AM
oghma's Avatar
Default Tire size
On a 22x10x11 size tire the height is 22 the rim is 10 and the width is 11????
Just need to make sure before I order some new tread.
Old Jul 4, 2004 | 12:13 PM
Kenji's Avatar
Default Tire size
for a 22x10-11:
22 is the height of the tire
10 is the width of the tire
11 is the height of the rim (this has to match the diameter of the breach in your tire)
Old Jul 5, 2004 | 05:44 PM
oghma's Avatar
Default Tire size
What kind of difference if any would going from the 22" tires that are on my 96 sport 400 and changing them to maybe 18 or 20. Would there be much of a difference???? and some recommendations would be appreciated. All I have been looking at are Holeshot only wanting to spend about $40 a piece.
Old Jul 6, 2004 | 06:55 AM
Kenji's Avatar
Default Tire size
Well, you can calculate the difference:
22" tire: 11" x 2 x pi = 69"
18" tire: 9" x 2 x pi = 56,5"
With an 18" tire your topspeed will be about 82% of your actual topspeed. I think there are some limitations, cos a tire which is too small can damage your engine. Please correct me if i'm wrong.
Old Jul 7, 2004 | 12:34 AM
mahnster's Avatar
Default Tire size
If you drop down from 22's to 18's you will lose two inches of ground clearance which is actually quite a bit. You will also notice you will have a better low end but will have a slower top speed. I dont think it would screw up your engine but it might wreck havoc on your drivetrain because of different gear ratios and everything. I will let the experts correct me on that one cause im not sure.
Bratman2
Aug 6, 2022 01:42 AM
Hankey Pankey
May 1, 2018 01:33 PM
Hankey Pankey
Aug 17, 2015 05:01 PM
2007 Grizzley 450
Aug 13, 2015 06:33 PM
rcappie4
Jul 18, 2015 07:51 AM
