pulling right
Well I would imagine that your tie rod is broken...Or check the bushing at the end of the tie rod....If it turns to the left and not to the right it might be broke on inside of the tie rod...not sure tho hope u find the problem...
dod u buy it used? if so it could be a nuymber of things.
1. psi diffrence between the 2 back tires. make sure there the same or it will pull.
2. bent tie rod. if one is bent your quad will pull to one side.
3. alignment. if your front end alignment isnt right you quad will pull to the side.
also im confused about "the right rear wheel is not turning". what do you mean buy this?
fordfaithful21
Dec 7, 2015 05:52 PM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
