stuck transmission
Old Jun 24, 2007 | 08:47 PM
bunkerf's Avatar
Default stuck transmission
have a 2004 400 sportsman and my transmission is stuck in reverse. has anyone ever had this problem.thanks
Old Jul 4, 2007 | 01:34 AM
GJRonK's Avatar
On my 500 there are two rods coming back from the gear shift box. Presume yours is the same. Probably the clutch is hanging up and not letting the gears loose so when you shift from Low to Reverse, the unit never got out of Low and is now jammed in two gears at the same time. Take a BFH (big friggen hammer) and tap the rearmost lever on top of the transmission (at the end of one of the rods) to the rear. That will knock it out of Low and Reverse.
Probably it will do it again until you change your belt or drive clutches, so keep the hammer with you on all rides.
GJRonK
Old Jul 4, 2007 | 02:44 PM
bunkerf's Avatar
thanks for your reply. I got the problem fixed by disconnecting the two shifter linkages and the shifter went back into neutral.[img]i/expressions/beer.gif[/img]and then I traded the bike in for a 2007 X2 500
Jeff Roper
Feb 1, 2022 11:48 AM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
mrtidy
Feb 3, 2016 05:00 PM
r1pilot83
Sep 27, 2015 07:38 PM
WilliamBos
Sep 22, 2015 04:07 PM
