Mud Lite Tires
Old Nov 29, 2007 | 11:45 AM
Suzuki Rider21's Avatar
Default Mud Lite Tires
Hey, i have a suzuki ozark 250 and i need to know:
how big of tires?
how much psi?
where can i buy them new but cheap?
THANKS GUYS
Old Dec 1, 2007 | 05:43 PM
SBuckJ's Avatar
Reconranger (automatics are for sissies)!
Try http://www.mudthrowers.com and enter the code LUGNUT when you order to get another 5% off.
Buck
Old Dec 3, 2007 | 12:15 PM
Hey Thanks at that website since the picture shows two tires does if i buy one of those with the pic w/ two tires does it come w/ a front tire and rear tire???
Old Dec 3, 2007 | 05:03 PM
SBuckJ's Avatar
What you should do is pick the tire you want. Fronts are usually smaller than the rear. In your case the fronts will be 22x7x11.Then pick the size then choose two for the quantity. Then do the same for the rear size tire which will be 22x11x9 and pick two for the quantity. The rear tires are 1" wider than stock but will be OK.
That should work for you.
You may want to just get two for the rear and leave your front alone seeing as how your front tires don't pull so the stock should be fine unless you want a thicker tire.
If you have any questions, e-mail Matt there and he'll answer any questions you have. At the end of the order they will ask for a coupon code. use LUGNUT and that will save 5%.
Good luck and have fun.
Buck
Old Dec 4, 2007 | 08:56 AM
Cmarti's Avatar
http://arizonamoto.com/Merchan...Category_Code=Mudlite
These were the cheapest I found for Mudlites. I put them on my kids 250's since they were light compared to other mud tires. GREATmud traction, rated to 7 pounds, i fill them at 4.5. The only problem is they bite deep in the sand along the river banks, and will bury the rear of the bike. I would consider a more all-purpose if you ride in any loose sand.
Old Dec 5, 2007 | 12:06 PM
Thanks ill check that out but where me and my friends ride we dont have alot of sand and were we do my friends bike w/ mud tires gets good traction but thanks ill check out the site!
Old Dec 5, 2007 | 12:14 PM
On that site is WAS cheaper but i couldnt find the front tires (22/7/11)
Old Dec 5, 2007 | 02:50 PM
SBuckJ's Avatar
They are in the drop down menu where it says "choose tire size". It should be SWL59 I think. The last one under 23" tires.
Good luck and good riding!
Buck
Sep 30, 2015 01:37 AM
Ahtatu
Sep 28, 2015 12:14 PM
PinkFloydEffect
Sep 25, 2015 06:31 PM
cboler9
Sep 24, 2015 08:35 PM
MooseHenden
Family ATVing Photos
Sep 20, 2015 04:14 PM
