14" vs. 12" wheels
Old Dec 16, 2007 | 03:02 PM
HONDA CRUSHER 93's Avatar
Default 14" vs. 12" wheels
What are the advantages of 14" wheels over 12" wheels, or is there one?
Old Dec 17, 2007 | 05:36 PM
Stones's Avatar
Default 14" vs. 12
im not sure the advantages. i hear the 14's are heavier than the same tires on a 12" rim. a dealer here built a 101 hp 750 brute and had to put 14's on it to get any traction at all
Old Dec 18, 2007 | 12:51 AM
mudslinginfool's Avatar
Does it in the Mud!
Default 14" vs. 12
in my opinion,looks! they look good but id rather have the extra side wall on a 12" wheel. wont have dented wheels as easily and if you get a flat you can ride on it with out messing up your rim. assuming you have 6 ply tires. 14" ,no advantage in my book. ask your self; what advantage would i have putting 20s on my truck that has stock 18s? just looks, and probably a more expensive tire.
Old Dec 18, 2007 | 12:56 AM
recon99's Avatar
Default 14" vs. 12
With the same size tire, the bigger wheel is going to give you less sidewall flex, which on the positive side can give you better handling, but the negative is a more rough ride. I think the bigger wheels are just mostly for the bling bling factor though, anybody putting big tires on a 4x4 probably doesn't care about small improvements in cornering.
badgerboy1
Sep 26, 2017 06:11 PM
Oct 10, 2015 10:20 AM
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
tysonbully
Sep 28, 2015 02:30 AM
r1pilot83
Sep 27, 2015 07:38 PM
