Interco Swamp Lites
Old Apr 14, 2008 | 12:09 AM
Kuch5's Avatar
Default Interco Swamp Lites
Anyone have any info on how well these wear?
Old Apr 16, 2008 | 03:05 AM
gohip2000's Avatar
well, mine have about 1000 miles and they are barely worn down.
I've ridden a decent amount of tar and done a lot of tire spinning on dirt.
They wear slowely for me.
Old Apr 16, 2008 | 09:54 PM
SBuckJ's Avatar
Reconranger (automatics are for sissies)!
Same here. I'm on my second set but only because I traded the last ATV in with them on (a mistake). Good all around tire at a good price.
Buck
Old Apr 17, 2008 | 07:47 AM
TimberedWolf250's Avatar
I have had mine for almost a year, and look like brand new still.
Gravel roads, mud, street , you name it they have been ridden on it.
Only problem with them is if you ride in your backyard after it has been raining for a while the wife wants to kill ya.lol They dig up the ground very easy, very aggressive tire ........ I LOVE IT
Old Apr 19, 2008 | 08:15 PM
MECHANIKE's Avatar
boy are those things hard! (thats what she said) i went from 2ply to these swamplites 6ply,the 8" wide for the scram went on ok but the 11" for the rear on the second tire broke the tire machine!!!!! will these things ever soften up.what pressure do you guys run,mine say 7 on the tire, scram says 4 infront 3 in back, i'm running 5 in both.
Old Apr 21, 2008 | 11:30 PM
gohip2000's Avatar
I had the same issue with the stiffness on mine. I put them down to 3.5 lbs each. I try to run them over rocks at this pressure to wear them in. it does take a long time for them to start flexing more, but eventually they get more pliable. I'm going to put my stock tires on because the swamplights are just to heavy and clunky for my hill and rock climbing.
Old Apr 22, 2008 | 10:15 AM
MECHANIKE's Avatar
thanx for your reply gohip,right now i have 5 pounds in them cause any less+the beads start to walk off the edge of the rim.i only have 2 miles on them,until a atv park opens.armorall helps alittle.
Old Apr 22, 2008 | 02:17 PM
gohip2000's Avatar
try keeping low pressure, but avoid heavy turning while your trying to break them in. that might help with the bead issue. Mine deflated at loaw pessure a couple of times, but I keep an air pump with me.
did you get 25" or 26"? the 26" are heavy and I wish I would've gone with the 25"s.
Old Apr 22, 2008 | 04:50 PM
MECHANIKE's Avatar
mine are 23x8-10 front+22x12-10 rear. the side rating on mine say 7psi but it feels like flintstonemobile.
Old Apr 23, 2008 | 03:50 PM
Kuch5's Avatar
thanks for the input but i found an awesome deal on some 27 inch mudlite xtr's
shimanok2
Jan 29, 2016 07:37 PM
MooseHenden
Family ATVing Photos
Sep 20, 2015 04:14 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
Sep 10, 2015 01:56 AM
1000gade
Sep 9, 2015 03:35 PM
