Side wall leak
Side wall leak
I have a small pin hole leak in one of my front tires (Mudlite XTR's 27') The hole is in the side of the tire and I was wondering if this can be repaired. Can I patch it from the inside or use slime, or something else?. I really don't want to spend 125-150 bucks for a new one. If someone with insight on this would respond I would greatly appreciated it..
Thank You!!
Thank You!!
Side wall leak
<div class="FTQUOTE"><begin quote>Originally posted by: Jtfchi
I have a tire that goes flat after a few days(I cant hear or see where it is leaking from) and I don't want to slime it my question is can I bring it to any local tire shop to have it looked at or will they look at me funny?</end quote></div>
It's probably a bead leak or a leaky valve. They can air up the tire and check for leaks, take the tire off and check out the tire and wheel, change the valve, and clean up the bead on the wheel. Sometimes there's rust or dirt keeping the bead from seating all the way.
