Will these rub? itp 589's 26x9x12 on front of polaris sportsman
Old May 23, 2009 | 12:01 AM
ronsfun96gt's Avatar
Default Will these rub? itp 589's 26x9x12 on front of polaris sportsman
Will 26x9x12 ITP 589's rub using stock wheels on front of a polaris sportsman 500 4x4? If so what can be done to make them work?
Old May 23, 2009 | 07:13 AM
mudslinginfool's Avatar
Does it in the Mud!
they should work just fine
Old May 23, 2009 | 02:14 PM
do you have this exact same set-up on your polaris ?
Old May 24, 2009 | 06:14 PM
Does it in the Mud!
nope, if stock is 25"(not sure what stock is though), then 26" will not matter, usually. If they do rub, you can try wheel spacers.
Old May 24, 2009 | 07:34 PM
upnort's Avatar
I'm thinking that they will likely rub on your tie rod ends. Mine did on my 05 800. Not sure on newer models though. Put a set of 1" hilifter spacers on.
Old May 24, 2009 | 08:50 PM
Well its sounding like i will have to go to spacers. Wonder if i could use a couple flatwashers to space out the wheel ?
Old May 26, 2009 | 09:20 AM
Kodiak450_06's Avatar
The 9x12's 589's are some fat, beefy tires, you sure you want them on the front? I have 589's in 27", in the front they are 9x10 and the rear is 9X12 and they stick out also throw mud on me. I was just going by replacing with stock size, with the exception of getting it in a 27". Anyway, when I looked at the tires after they shippped to me I was like wow! They are huge! Luckily they fit, but I can't imagine having that 9x12 in the front, harder to steer, and possibly might not fit to begin with.
Old May 26, 2009 | 02:00 PM
Does it in the Mud!
im confused,what size is stock on the machine? a 26x9x12 is not that big of a tire. To make sure were on the same page ronsfun you are saying the wheel is 26 inches tall, 9 inches wide, and is on a 12 inch rim. Now kodiak450 is making it sound like its a 12 inch wide tire on a 9 inch rim. in this case,yes its big and beefy and wont turn very well and will most likely rub. My understanding that stock is 25x8x12 which means the 26s are not much bigger, same size rim only 1 inch wider(or half inch wider on each side, however you want to look at it),and 1 inch taller( which means half inch more ground clearance). I dont have a polaris so i cant say much,but im trying to help figure this out with you guys. I have an arctic cat 700 with 28x10x12 on all 4 corners and it drives perfectly fine with out rubbing,of course they are both different machines but a 10 inch wide tire handles very well for me. So a 9 inch wide tire should do just fine for you. Sorry for the long post, just trying to get things figured out.
Old May 27, 2009 | 06:57 AM
weedy's Avatar
'5 minutes worth of planning equals 30 minutes of execution'
They will rub with stock wheels. Spacers are an option.
Old Jun 2, 2009 | 07:06 PM
You are right mudslinginfool. Im saying 26x9x12. Where the 9 is the width, not 12" wide as some else was talking. At any rate i have the tires on the polaris now and the front tire is BARELY rubbing the tie rod end.
So im investigating solutions. I dont want to use washers or spacers though. Thanks
neilbedwell
Nov 10, 2018 11:02 AM
Mphillips
Jul 29, 2015 08:53 PM
yellowpolaris
Jun 21, 2015 11:13 AM
DOAinNY
Jun 11, 2015 10:34 PM
May 27, 2015 11:15 AM
