1985 Suzuki Lt230 clutch issues
Old 05-12-2016, 05:11 PM
eanburch's Avatar
Default 1985 Suzuki Lt230 clutch issues
i have a 1985 Suzuki 230 quadrunner that i just rebuild that engine on and i replaced the clutch to. and now the the clutch will disengage went there pressure put to the wheel. and if adjusted thousand times. Anyone with a little more knowledge then me your help would be helpful.
Old 05-13-2016, 08:55 AM
Scooter86's Avatar
Knows Old ATV Questions!
So if I understand that properly, after rebuild, when you apply power the clutch now slips? Did this start right after the rebuild? If so, I would think something is not assembled properly. Did you use the proper number of clutch plates, and in the right sequence? Is the cable adjusted properly and routed correctly?
Old 05-17-2016, 08:02 AM
eanburch's Avatar
yes it started right after the rebuilds. and it a centrifugal with a basket clutch, and i only replaced the centrifugal clutch and just cleaned up and oil the basket clutch. and went i pick up the back tire it engages and move but the second you put pressure against the back wheels it it slips and doesn't move.
Old 05-17-2016, 08:44 AM
Scooter86's Avatar
My suspicion is that something was not installed correctly. Maybe you have the steel and fiber plates in the wrong order, or the springs are not torqued down fully?
Old 05-18-2016, 01:39 AM
Sounds like the old friction plates you reused are either oil saturated or worn out causing the slipping.Vesrah Friction Plates for Suzuki LT230GE Quadrunner 230 85 86 | eBay
ggjayjay
33
08-01-2016 11:10 AM
79f250guy
06-17-2016 12:34 PM
96superflow
10
06-09-2016 05:13 PM
ctxkiger
05-17-2016 08:39 AM
Quick Reply: 1985 Suzuki Lt230 clutch issues
