Beartracker Wheel Swap?
Old 03-02-2002 | 03:01 PM
HunterExplorer's Avatar
Does anyone know if there are any 25" wheels that will fit a Yamaha Beartracker? Considering swapping for the taller 25" ones for more ground clearance. Any info appreciated. Thanks.
Old 03-07-2002 | 08:05 AM
REDBEAR4x4's Avatar
25" tires will fit the beartracker...
Old 03-08-2002 | 10:00 AM
Thanks REDBEAR, but I need just a little more info please. I know 25" tires will fit the Beartracker on the 10" rims that are stock, but am wondering if any 12" rims from any other machines will fit the hubs of the Tracker. If there is such an animal, then could possably go even taller than 25" tires. What have you got on your Beartracker?
Thanks again for your help.
Old 12-30-2004 | 03:20 PM
UltimateAussie's Avatar
Default Beartracker Wheel Swap?
I personaly wouldnt put any taller than 23s on the beartracker. i have one and they really dont have all that much power to spare to turn those bigg a$$ wheels/tires. if you want more ground clearance then i would get a bigger bike with more power. but if you dont want to spend the money on a bigger bike like me, then you will have to sacrafice lots of power for the bigger wheels. But i think one of the only reasons for needing pmore ground clearance is to go through deep mud or crawl over big logs, in which both cases are going to need all the power thay can get.
Joe454
11-20-2020 02:19 PM
badgerboy1
09-26-2017 07:11 PM
10-10-2015 11:20 AM
cboler9
09-24-2015 09:35 PM
Quick Reply: Beartracker Wheel Swap?
