Cheap lift for a quad
Old Jun 5, 2002 | 03:15 AM
Jerms's Avatar
I was in the local auto parts store today and I happened to notice some of those little "wedges" that you put in your coil springs to give them more lift. Would it be okay to use them on a quad to give a bit of a lift, and if so will it prove beneficial? I just put some 25"'s on my Honda 300 and I'd like a little more clearance between the rubber and the fenders.
JC
Old Jun 12, 2002 | 09:56 AM
warriormike13613's Avatar
Have you tried this? sounds like a good idea.
Old Jun 20, 2002 | 09:22 AM
BigBearChris's Avatar
Bad idea! I've tried that on my 4Runner and it caused a pressure point and bent the coil in one spot. Might not be as bad on an ATV, cuz it doesn't weigh that much, compared to a SUV. If you can find the rubber/fiberglass ring, cut it down to fit, it would probably work better than the little aluminum wedges. The ring should slide in the coils and stay put. Good luck, Chris
Reactant
Mar 30, 2022 02:08 AM
Frisky2050
Apr 9, 2020 11:19 AM
greg74
Sep 10, 2019 03:03 PM
RickyMac
Mar 5, 2016 07:27 AM
1966F100
Jul 12, 2015 03:08 AM
