Reinforcing Rings?
4-wheel atv action used to have an advertisement for them, but i just looked and they dont now. if i remember correctly, they start at $20 each, and as for installing them, all you need to do is center them on your rim, use a mig/tig aluminum welder, and tack them. there are different ways to weld them, one is tacking in 4-10 places, and welding over the tacks. the other has to do with car bodywork, where you tack it in little places until the circle is complete, asto not heat the aluminum as much. but it looks better if you do a regular weld.
btw, you can also use oxy torch with it, but make sure you have an oxidizing flame, or you will certainly cut through the metal!
Steeldon
09-09-2015 09:38 AM
