Glamis... which Raptor pipe won't get me in trouble?
I have an '03 Alba Raptor w/ an Alba pipe kit(Supertrap made and Alba stamped) on it. It has an open airbox, stage 3 Jet kit and I removed the Supertrap Baffles and put the Alba open tip on it for 4 more Horses. Pushing 59 which is big, but don't get in trouble ever. Even took it to Pizmo and they are strict. Not a problem in Glamis w/ all the V-8's around, so buy what gives you the power boost you want. Alba pipes are perfect and you can switch the tips easily enough to make it useable if it gets stricter on decibal levels. Order it from Alba Yamaha in Poway, Ca. 92064.
GEOLIQUID- the fmf-q muffler is a good choice for a legal pipe for the raptor(mine came in at 92 db) and it builds good power in the midrange which is very usable for duning.you will have others tell you that the q is not a good choice because it does not build as much peak horsepower but the midrange power that it builds is very good for climbing dunes and drag racing up hills.i think that if you installed the q and also put on a better breathing air filter along with re jetting that you would be very happy with the performance gain and you would be legal.if you can afford it the power bomb header is a good addition to go with the q and it will help with that midrange power even more.
Go With the pipe that won the 2002 and 2003 four stroke wars at glamis. Curtis Sparks Racing, I think very few people on here would argue that his pipes make a dump load of power,and u can also interchange the tip with open or disc for db prefrence. Tell them
Danny g sent u 661-872-4343
Pushing 59 what, HP? If so what motor mods do you have other than pipe and airbox?
greg86hd
09-16-2015 12:32 AM
