Dunes and Dune Machines Discussion on dunes and dune machines.
engine temp
Old Jan 26, 2004 | 01:34 PM
jstaguy24's Avatar
Default engine temp
Im Installing a thermometer on my quad so I can monitor Engine temp when racing up Sand Mountain. Anyone know what temp a 2 stroke motor should run. It is a Honda Cr500 motor but im sure most two strokes should run close to the same temp. Any info would be great
thanks
Old Jan 26, 2004 | 07:56 PM
bansheeesmoker's Avatar
Default engine temp
I need to know to, where did you get your guage?
Old Jan 27, 2004 | 11:11 AM
jstaguy24's Avatar
Default engine temp
I do heating and a/c work so I got it through one of our suppliers. Johnstone supply if you have any of those in your area. It is a digital solar powered thermometer and has a sensor to strap wherever you want to get the best reading
Old Jan 29, 2004 | 12:20 AM
desracers's Avatar
Default engine temp
I believe the eng temp for 2 stroke should be around 1000 1200 degrees. The melting point is around 1350 degrees.
I used to have EGT on my banshee pipes and I was running around 1200 and make sure it never got any higher 1300 at all.
Also when you do that make sure do the plug check so you know what the plug like at certain temp.
Old Jan 29, 2004 | 12:24 AM
desracers's Avatar
Default engine temp
here another response. I misread the first note......
The engine temp should be around 180-190 degree..... Somewhere around there....
Thought you were talking about the EGT gauge..... Sorry
Old Jan 31, 2004 | 10:54 PM
Chris142's Avatar
Default engine temp
Every 1lb of radiator cap pressure raises the boiling point 3 degrees (at sea level and using water only.)
So with a 13 lb cap, straight water and perfect conditions it should boil at 251 deg. Adding coolant up to 50% will raise the boiling point some....Say 260.
Personally I would start watching the guage at 220 degrees and turn downhill at 230 to cool things off.
Let us/me know what the operating temp was on the big hills. I'm curious.
Old Feb 1, 2004 | 01:51 PM
jstaguy24's Avatar
Default engine temp
ok guys thanks for the info Hopefully im going to dumont in a couple weeks so Ill get to test it out and see. Ill let you know
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Cummins Driver
Sep 11, 2019 01:22 PM
DeFox500
Jul 26, 2015 06:32 PM
ltrmc02
Jul 22, 2015 04:50 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
