Dunes and Dune Machines Discussion on dunes and dune machines.
Need a flag
Old Mar 20, 2004 | 10:12 AM
Starky's Avatar
Default Need a flag
I need to put a flag on the Raptor for my dune trip. What do I need to look for. How long, what kind of base. Thanks for the help.
Old Mar 20, 2004 | 10:31 AM
RAPTOR660RBUD's Avatar
Default Need a flag
all that u need to do is go to your local dealer and ask them if they have flags. all flags will be about the same size and the raptor's stock grab bar has a mount for the flag. most flags will have a thread and two bolts to tighten. If your local dealer doesnt have a flag then just wait until you go down to the dunes then all the rental places will have them. by the way they should be around ten bucks
Old Mar 20, 2004 | 05:37 PM
maddog56's Avatar
Default Need a flag
Just wait till you get to the dunes you plan on riding to buy the flag. Most dunes require a certain height or flag color or shape. The local shop at the dunes will have hundreds of these in stock, and usually for only about 25 bucks a piece.
Old Mar 20, 2004 | 07:59 PM
TheSorb's Avatar
Default Need a flag
I highly recommend you go with a steel rod & flag. It costs more, but it'll last forever (the rod, that is) and you can easily replace the flag once it wears out. Believe me, it sucks to be out in the middle of nowhere on the sand when you realize your plastic flag pole broke in half somewhere two miles back![img]i/expressions/face-icon-small-wink.gif[/img]
Old Mar 20, 2004 | 09:25 PM
maddog56's Avatar
Default Need a flag
My pole is fiberglass, stronger than plastic and more flexible and forgiving than steel. All 3 of mine have held up great for the last few years.
Old Mar 20, 2004 | 10:06 PM
Starky's Avatar
Default Need a flag
Thanks for all the input. I think I'll get a cheap one to take with me then see what they have or require when I get to the different spots. Somewhere I think I have an 8 foot fiberglass whip antenna for a CB. That would probably work great if I could find it.
Old Mar 21, 2004 | 12:51 AM
Spudss's Avatar
Default Need a flag
I would look for the figerglass on-piece whips with the spring built in at the base of the whip... They will stand up to roll-overs and just about everything else you can dish out...you will be better off buying on from the dunes.. A little more cash but it will be worth it... Speacially after you buy a cheapy two piece and it falls apart and you look back and you only have half a whip.. Then you have to shell out more dough for a new one....Steel sucks espeacially in a roll-over...Try to find a one-piece with a spring at the base.. Thats the best buy...
Old Mar 21, 2004 | 02:08 AM
duneittilludie's Avatar
Default Need a flag
Starky-I use a (POP-IT)flag and mount and i would recommend that you try to find a dealer who carries them in your area.The pop it flag system consists of a mount that has a female connection that snaps into a male connection so that if you have a get off the flag will pop out of the mount and then you can simply snap it back into place.I have been using the pop its for years and they hold up very well and they work as advertised.I have always stayed away from a steel flag mount like a car antenna or something similar because although it may be a remote chance there is a chance that in a accident it could snap off and become a skewer that could impail you if your quad rolled on you during a roll over.The possible danger of the steel flag mount is something to consider.
Old Mar 21, 2004 | 01:58 PM
Starky's Avatar
Default Need a flag
Getting stabbed by my flag, that's something i didn't think about. I was going to ask if anybody had tried the pop-it mount. I saw them in Dennis Kirk and thought they looked pretty good. Thanks for the info.
Old Mar 22, 2004 | 12:33 AM
ShadyRascal's Avatar
Default Need a flag
I put pop-its on my kids' Blasters, and they have survived rollovers, enough to pay the extra cost for them. I think I spent 29 bucks, whereas our cheapie two piece ones are ten or twelve.
MikeyBoyesq
Sep 22, 2015 10:02 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
MikeyBoyesq
Aug 10, 2015 11:11 AM
ugly
11
Oct 8, 2001 07:11 PM
cowboy
Nov 11, 2000 03:32 PM
