Dunes and Dune Machines Discussion on dunes and dune machines.
help on buying paddles!!!
Old Aug 3, 2004 | 08:26 PM
julikikas's Avatar
Default help on buying paddles!!!
I'm looking into buying some skat track haulers but need some help. How many paddles should i get 8,9,10? They are gonna be mounted on a banshee with toomey t5 pipes. i weght 225 lbs. i mostly like to ride and drag. I mostly ride in Pismo Beach and in Glamis. Any help would be great!!!
Old Aug 3, 2004 | 09:10 PM
Voodoothenoob's Avatar
get the extremes in 8 paddle
Old Aug 7, 2004 | 01:45 PM
dunner04's Avatar
my buddy has a banshee with fmf pipes he runs 10 paddle tires hooks up like crazy. gooood for dragging at glamis see you there at holloween
Old Aug 7, 2004 | 05:40 PM
Outlawlawndragster's Avatar
Scat haulers go with a 21x11x8 or a 22x11x8 sometime you will find a 22x12x8 or 21x12x8 . and put them on 8" wide wheels .
They will have a highround crown look to them instead of flat . this way when you get up on speed only the top will be cupping sand and you will run faster and climb faster . Run them at about 3.1/2 pounds of air pressure
Dont go with a 9" or 10 You lose side wall and then they run flatter and cause to much drag at top end
Go with a 8 or 9 paddle
Old Aug 8, 2004 | 05:22 PM
SANDMAN430's Avatar
9 paddle always seems safe.
Old Aug 12, 2004 | 01:45 AM
Freakneh's Avatar
I always ran 8 paddle Haulers on a 10" rim, and really liked them. I haven't used the Extremes, but they sound like they're the best out right now.
J.
Old Aug 13, 2004 | 12:27 AM
dunerdogg's Avatar
If you run a 10 paddle you might have pretty goood bottom end but once you get to your top end your not gonna run as great so I sujest that you go with the 8 paddle ultra bufs but those are a little more expensive .... if not those go with the 8 paddle extremes ... Austin
Old Aug 13, 2004 | 12:31 AM
scrambler123's Avatar
i run 21x12x8 10 paddle on 8 inch wide wheels they work extremely well.
slowgsxr97
Sep 8, 2015 07:33 PM
rawbdiggity
Sep 7, 2015 12:05 PM
antiguogrumete
Sep 5, 2015 03:41 AM
mrmickman123
Technical and How-To Articles
Aug 30, 2015 10:37 PM
Aug 25, 2015 11:16 PM
