Exotic and Modified Quads Share photos of radical and modified ATVs
I NEED HELP!! 350 warrior
Old May 19, 2008 | 10:09 PM
HENROC5256's Avatar
Default I NEED HELP!! 350 warrior
I JUST PICKED UP A 98 WARRIOR FOR CHEAP. ITS IN GOOD CONDITION BUT WHEN I FIRST START IT IT SMOKES FOR ABOUT 5,6 SECONDS THEN CLEARS UP. ONCES ITS WARMED UP IF I THROTTLE IT A LITTLE IT POPS & BOGS OUT AS IF IT WERE GONNA SHUT OFF. WHEN RIDING IT, IT SEEMS FINE, BUT AFTER GOING OVER A FEW HILLS & SLOWING DOWN TO A STOP IT SHUTS OFF. I'VE CHANGED THE FUEL, SPARK PLUG, OIL, & FILTERS. CAN ANYONE HELP ME OUT OR GIVE ME ANY POINTERS? THANK YOU!
Old May 20, 2008 | 03:35 PM
marks620's Avatar
Blue smoke means oil burning-probably worn valve guides. Not the biggest of your problems, though eventually you may want to get it fixed by having the head rebuilt with new valve guides (and probably new valves, too). Just replace the spark plug every few rides in the mean time!
The problem with how it runs is most likely in the carb. Pull it off and clean all the jets and passageways, including the accelerator pump circuit (if should has one).
Good luck.
Also-this is posted in the wrong section!
Old Nov 26, 2008 | 01:21 PM
hemicuda7193's Avatar
Default I NEED HELP!! 350 warrior"></title><script src=
do u know if it has ever been sunk under water. cuz that is a way that your problem can happen
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
