Calling all you math heads, answer me this!
Old Jun 8, 2006 | 12:21 AM
  #121
Knutz's Avatar
Default Calling all you math heads, answer me this!
Originally posted by: BryceGTX
The problem is that math is an absolute, it's NOT based on assumptions. It's either right or it's wrong. There is no inbetween of math. 1+1=2, not somewere around 2. Not 3 because we were not sure it 1 was actually 1. If you are claiming to solve a problem with math, you must have an absolute answer. If the answer isn't absolute, the math isn't solved.
Tell me what 1/3 is?? Is it 0.3 or 0.33 or 0.333 or 0.3333.. Not sure.. it is not exact.
Tell me what velocity is? We know it as the derivative of the position function. The derivative is defined as the limit of the delta position divided by the delta time as the delta time goes to zero. Doesn't sound too exact to me.
Tell me how fast your car is going. Is it going 50 mph or 50.1 or 50.12 or 50.123. Doesn't sound to exact to me.
OK, now you have just gotten stupid!
1/3 is 1 divided by three. The answer is .3 repeating infinatly.
If you have absolute numbers to plug into the velocity formula, you get an absolute answer.
The "speed" of my car is not a mathmatical equation. 50, 50.1, 50.12, or 50.123 are simply numbers that could be the answer to an equation that determines my velocity, or speed.
To argue that math is not absolute, cost you all credability.
I was going to actually look at the dyno you linked to, but your rebutals have gotten less and less factual and less intelligent. If it's like the 18 that I found that were rated to handle the HP, they would in no way work on a nitro-methane motor. They were designed for steady state, turbine, gas or diesel motors.
BTW, because I have seen something does not mean that I have it. I'm sorry, the top fuel team that was showing me around does not hand out copies of their telemetry. I know, it's silly of them.
Old Jun 8, 2006 | 12:36 AM
  #122
BryceGTX's Avatar
While that is a chassis dyno, if you read about it you will find it's purpose. Is was designed to provide a load to simulate road conditions, not to measure HP. It does take a power measurement to determine the load to apply, but that measurement is descibed as a secondary purpose and not expressed in any common way. In actuallity, it method of applying a load has since proven to be unreliable as it uses a disk brake that has shown to change drag co-efficient as it heats up. Modern load control dyno's use a watter brake or eddy-current for load. While you did your research to find a dyno, you did nothing to disprove my statements. The infomation you provided has no relavence to our "discussion". It simply showed that Mr. Dobeck is not the only person to invent a chassis dyno, I will concide that point although I'm not sure of it's importance.
There are a total of 429 patents on chassis dynos. Probably 50 of them predate 1985. If you read some of the other patents, yopu will find water brakes and eddy current chassis dynos that predate 1985. A road load simulation is only one of the modes that you put a chassis dyno in. HP calculation is a basic function of a chassis dyno. Any chassis dyno will calculate HP. The real inovation was the road load simulation. And the most modern dynos do not use eddy current or water brakes, they use AC dynos. Now the cheap chassis dynos might use eddy current or water brakes. One reason is, you cannot reproduce coast down properly with an eddy or water brake. I really don't car about Dobeck.. because the calculation of the Vmax have no place in any standard chassis dyno.
Old Jun 8, 2006 | 12:43 AM
  #123
BryceGTX's Avatar
My entire point has been that you can't prove how close or far off your calculations are! What part of that do you fail to understand! If you retained what you read, I stated something along the lines of you could be as close as any guess. I MAINTAIN THAT KNOWONE CAN DETERMINE HOW FAR OFF YOUR CALCULATIONS ARE BECAUSE THEY CAN NOT CALCULATE THE CORRECT ANSWER! Besides, your said this is a discusion, when I called it a "pissing match", now it's an argument?
I can calculate how far off my calculations are. Any one who applies math to a problem has an idea how far off his calculations are. I don't see any point in posting it in this thread because it requires assumptions. Given that you cannot even accept the basics assumptions of my simple calculations, its unlikely that you will accept my assumptions of my error calculations. I am just trying to get you to think about the problem so you might be able to come to some conclusion about how far off the math could be. Not how far off it is.. but how far off it could be.
Old Jun 8, 2006 | 12:48 AM
  #124
BryceGTX's Avatar
Oh? and why is this dyno I have listed not rated for the nitro methethane motor?
Old Jun 8, 2006 | 03:16 AM
  #125
Knutz's Avatar
Originally posted by: KnutzIf it's like the 18 that I found that were rated to handle the HP.....
Read all of the quote that you posted, it answers your question.
I'm done with the thread. When it began, I respected you as an intelligent person that simply gave a (suposed)factual answer based on an unproven assumption. Your points have gotten less and less factual and the discussion has deteriorated to a moronic level. You will continue to believe that math is some black magic that doesn't require or solve for factual data. I imagine that you "discuss" any problems your children may get wrong on their math tests, with their teachers, supporting the "disscusion" with assumptions.
[note- this is in no way intended as an insult towards your children, all children make mistakes sometimes]
Old Jun 8, 2006 | 01:20 PM
  #126
BryceGTX's Avatar
That is where you are wrong. This dyno can easily handle the nitro methane motor. Water dynos have been testing race engines since time begin. There is no difference there. AS far as suggesting that just because water dynos test diesel engines they cannot test nitro engines.. A diesel engine has a torque rise in the milliseconds region. Much faster than any gas engine that you will ever find. I think you will find that the torque rise of a nitro methane engine is not faster than a diesel engine. The big difference between a nitro methane engine and a diesel engine is that the nitro methane egine can accelerate faster than a diesel engine because of the lower inertia. So if we are attempting to simulate the load on a top fueler with a water dyno, we simply add an inertia to the dyno so the sum of the dyno inertia and the added inertia is equal to the effective inertia of the top fueler. You will then find, you can easily use the water dyno for acceleration tests and steady state tests.
Old Jun 8, 2006 | 06:01 PM
  #127
motox26's Avatar
Shed Knocker Rider
Harley Punk!
I think Knutz can't accept the fact that he is out of his league.
Old Jun 8, 2006 | 06:12 PM
  #128
DragonDJ11's Avatar
Please explain how you figured that!!!! He is completly correct as far as the math goes I know. The answer is based off of variables that are assumed to be absolute. The answer may be within an exceptable range for error, but still not exact. Great math has been done, and calcualtions seem to be in order. However, when a variable is assumed to be an absolute you turn a mathmatical fact into nothing more then a Hypothosis. An educated guess. Nothing more, nothing less. That being said, some of the greatest things in history have been created that way.......Also, some of the biffest blunders.
Old Jun 8, 2006 | 07:47 PM
  #129
squeege's Avatar
Maybe this style math was used on the neworleans levees...LOL [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jun 8, 2006 | 07:51 PM
  #130
way2fst's Avatar
freebird see what u started....u and ur math homework!!!!
jk lol
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
