Looking For GOOD Oil
Old Dec 23, 2009 | 10:31 PM
canoeman43's Avatar
Default Looking For GOOD Oil
Iv been doing some reaserch on oil ratings and comparisons,we buy about a two or three gallons of oil every month or so and Im trying to figure out whats the BEST possible oil for the money.So far all the web searches keep coming up with Amsoil being one of the best,Its still pretty pricey,anyone have any more suggestions?
Old Dec 24, 2009 | 03:12 AM
chuck_raduenz's Avatar
any oil is good id say. just use the correct weight oil recommended. iv been useing mobile 1 oil in my new wheeler. its cheaper than the oem. but yet iv see alota people useing it in there wheelers with out an issue. iv evon used a cheap oil in my 2000 sold it with 7k miles on it. with no engine issues. dint burn a drop.
Old Dec 24, 2009 | 03:42 AM
aaronrkelly's Avatar
If your looking for good oil, your on the right track with Amsoil....
If your looking for good enough oil, almost anything will do the job. I run older air cooled stuff.....so I run Rotella T 15w40 HD oil. Others get along great with a good car oil.
Old Dec 24, 2009 | 10:53 AM
coyote170's Avatar
I use nothing but Valvoline ATV oil now it is a great product and
run it in my atv's and mowers also.
Old Dec 24, 2009 | 10:54 AM
DODGE57HEMI's Avatar
Mopar Man!
Valvoline in the Grizz and Generators and Redline in the Raptor!
Old Dec 24, 2009 | 12:28 PM
davethegunman's Avatar
Originally Posted by aaronrkelly
.... Others get along great with a good car oil.
I would not run regular automotive oil in a wet clutch system. I tried it in a pinch once. The clutches slipped terribly bad. I went to the dealership and got the proper oil two days later and changed the oil and filter again.
I too have recently started using the Valvoline ATV 10w40. I found it at Autozone for $4.99 USD. It is a little cheaper than the OEM oil.
Old Dec 24, 2009 | 01:53 PM
OneTenCC's Avatar
Originally Posted by davethegunman
I would not run regular automotive oil in a wet clutch system..
+1 to that. For an awesome, low cost, off the shelf heavy-duty engine oil, like said, you cannot beat Shell Rotella-T 15w40, or better yet Rotella-T 5w40. If you can stand shopping at Walmart, they tend to have the best gallon (or 5qt) jug prices on oils.
Joel
Old Dec 24, 2009 | 01:59 PM
Any car oil that is NOT Energy Conserving will not cause any clutch issues.....you have to check for the EC starburst on the bottle. You are correct that if its EC it "can" cause problems.
Everything I run is air cooled....which means Im running 10w40.....in this weight Ive never seen an EC oil, they are primarily only in the lighter weights.
As for Rotella T HD 15w40....which is a automotive/heavy truck oil - it actually meets JASO specs per testing they just dont bother to go thru the process for certification or advertise it.
Nondem
Feb 22, 2020 12:20 PM
Unzzy66
Jul 11, 2015 10:01 PM
cornermike
Jul 8, 2015 11:44 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
