HELP NEEDED warrior or ltz400???????
Old Apr 8, 2010 | 07:44 PM
joejo33's Avatar
Default HELP NEEDED warrior or ltz400???????
ok i sold my 300ex a little while back now its time to get back on track im not sure what to buy i found two really good deals but don't know which to take between a 03 warrior pretty much mint cond. extra rims and tires real nice bike adult owned. The other is a 04 ltz 400 nice shape has new axle bearings and a lone star extended rear axle other than that all stock could use front tires soon rears tires are good. see the pics below i like to go trail riding and go fast equally whats best for both? which has better handling?
thank,joe ALSO I talked BOTH DOWN TO $1500 WHICH I THINK IS REAL GOOD EITHER WAY
Attached Thumbnails HELP NEEDED  warrior or ltz400???????-3n53m93oc5v45q25x1a47c86bac6b696f1666.jpg   HELP NEEDED  warrior or ltz400???????-3n83kb3o85v15w15r3a478cb67992c10b185b.jpg
Old Apr 14, 2010 | 12:28 PM
SundiroSunray90's Avatar
i would go with the second one, but thats me. like you said you talked them down to 1500 so there you go. just research it a bit more, find out some more specifics on the particular machines then make a decision based on what you find. its probably not a good idea to just take the advice of someone here without doing some outside research. that way you can draw the best conclusion based on what you find. Good Luck.
Old Apr 14, 2010 | 01:03 PM
joejo33's Avatar
yea i went with the ltz not the origanal one i was looking at but one that i found only 5 mins from my house the only reason i was thinking of the warrior was because it was an hour closer than the other ltz but the one i bought is great although it was a little too loud for were i live so i put the stock exuast on but its jetted and has aftermarket k&n air filter now going back to stock pipe am i going to have any problems?
Attached Thumbnails HELP NEEDED  warrior or ltz400???????-img00225-20100414-1208.jpg
Old Apr 14, 2010 | 01:07 PM
i don't think you should. i'm not 100% sure tho. but i don't think the air filter and stuff would affect the pipe or anything else but exhaust. i could be wrong tho.
Old Apr 14, 2010 | 02:51 PM
DODGE57HEMI's Avatar
Mopar Man!
As much as I am a Yamaha fan it sure is hard to beat the Zuke 400's in that size and class of a machine! I would ride both and go with the one that gives you the best gut feeling!
Old Apr 21, 2010 | 04:19 PM
Sand Hog's Avatar
Default help needed
Suzuki all the the the LTZ400 is a good solid quad, the only one bigger in 2wd Suzuki is the LTR450
jrooker6
Ask the Editor
11
Apr 21, 2016 07:35 PM
Mphillips
Jul 2, 2015 07:20 PM
Nelson
Jun 20, 2015 01:59 PM
Jun 3, 2015 01:40 PM
