T-Raxx Turns ATVs into Front Loaders
Old Dec 8, 2010 | 05:57 PM
ATV Connection Reporter's Avatar
ATV Reporter
Default T-Raxx Turns ATVs into Front Loaders
Hey guys check out this new device by T-Raxx!
Originally Posted by ATV Connection
We here at ATV Connection are no strangers to witnessing ATVs being used for all sorts of manual labor: Cutting grass, hauling logs, plowing snow and so on. About the only thing we haven’t thought possible was turning an ATV into a forklift… until now.
T-RAXX has brought the Ground-Force out to work; a fully functional, all-electric front-end loader to the world of quads. Lift, plow, dig, drag, and push. It can be used for landscaping, light excavating, snow removal, wood hauling and even picking up another ATV to chest level for easier maintenance!
Be sure to read the entire article by clicking here!
Would this front-end loader be useful for your purposes?
Old Dec 8, 2010 | 11:44 PM
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
pretty good idea but, it looks like it could have the potential to cause alot of wear and tear to the front end.
Old Dec 9, 2010 | 09:41 AM
Raven95150's Avatar
Actually, this really isn't anything new. Swisher has made forklift and front loader attachments for several years.
http://www.swisherinc.com/forklift.asp
http://www.swisherinc.com/dump_bucket.asp
Old Dec 9, 2010 | 11:04 AM
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
man- that looks like one fast track to a broken atv! the rig alone must weigh 100lbs- won't be good for much of a load! Hell, just trying to steer with my 60" moose plow attached is a hassle and unstable, can't imagine steering with a loaded set of forks! The flex in the tires alone would cause it to lean too much- it needs solid tires- I'm assuming there's a counter weight on the back? Very skeptical about it picking up an atv to chest level to work on- maybe a 90cc- it aint picking up no big bore atv for sure!
and wait- are they actually comparing renting a skid steer ($175 for 24 hours) that is capable of lifting, hauling and pulling tons of force to a $1500 set of forks you bolt on to an atv???
please! lets get real here and make an accurate comparison, say.... "forget about paying your friends to help you lift that kitchen stove into your pick up- for only $1500 you can waste your money on these atv forks!"
Old Dec 9, 2010 | 06:10 PM
merrickvilleguy's Avatar
Its a total waste, the capacity would be too small to be useful, and the wear and tear/stability issues would be dangerous and costly.
Why try to make an atv into something it isn't ? It isn't a tractor/skid steer/fork list/bull dozer ... its an atv
now ... that being said ... if they made a trailer that would center the forks between a set of axles that could be towed ... then at least it would be safer and useful
but in the end, if you move enough stuff to require forks ... why not get a loader ?
Old Dec 9, 2010 | 06:27 PM
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
I've actually found fork trucks on CL for $1500 - $2500.
I can't imagine they sell many of these setups.
MikeyBoyesq
Nov 27, 2020 02:44 PM
txkevin
Sep 21, 2015 02:02 PM
jayking232003
Jun 9, 2015 02:54 PM
Dpearson03
Utility ATVs
May 29, 2015 04:51 AM
