250 will not restart.
Old Jun 21, 2011 | 09:18 PM
jlboling's Avatar
Default 250 will not restart.
I have a 1990 Polaris Trail Boss 250. Will start and run fine when cold. No noticable issues. After I shut it down, it will not restart until it cools. Plug is firing. Compression on cold engine is about 105psi. Any ideas?
Old Jun 21, 2011 | 11:19 PM
ryder133's Avatar
I know it may sound stupid but check your battery connections and see if there on right. Could be it starts then the vibrations rattle you connections loose then you let it cool down but when you get on it it reconnects? XD
Old Jun 21, 2011 | 11:52 PM
jlboling's Avatar
Actually bought a new battery tonight. Still have problem.
Old Jun 21, 2011 | 11:59 PM
ryder133's Avatar
I meant wires leading to the battery.
Old Jun 22, 2011 | 08:47 AM
Jaster94's Avatar
maybe your valves need an adjustment. i can't imagine you going through a vapor lock scenario. but then again, you didn't state how long you run the quad before it won't start up warm. normal operating temps?
Old Jun 22, 2011 | 10:18 AM
jlboling's Avatar
Checked battery cables terminals and connections. All clean and tight. I do get atv up to normal operating temp. This is a 2 stroke. Does it have valves that can be adjusted.
QuadRiders
Oct 22, 2015 04:13 PM
donthavaclue
Nov 13, 2008 07:29 PM
fireCapt911
Technical and How-To Articles
Nov 9, 2008 01:48 PM
bhaller
ATC 3-Wheelers
Oct 29, 2008 01:17 AM
