Edge 90cc new to the game
Old Feb 2, 2013 | 10:41 PM
casper510's Avatar
Question Edge 90cc new to the game
Hi Ya'll,
I'm a newbie to the quad world. I received a "free broken quad" from my cousin and have been trying to get it running. I can't seem ti get it ti fire up. Here's what I've done so far. I replace the spark plug, CDI, Ignition coil, recahrged the battery, seems to be holding the charge, cleaned the carburator. I found a small chain behind the Stator that had come lose so I reinstalled it. I've check all the wires and found some corroded connections and replaced them. When I try to start it I make sure the brake is on, I've read that some will not start without the brakes engaged. I have clean fuel, and new oil change. I don't have a repair manuel to use as a referance. I've been watching a lot of on line video's and reading whatever I can get my hands on. Does anyone have any suggestions or know of a good repair manuel that would come in handy? I'd appreciate any help.
Old Feb 3, 2013 | 02:25 AM
User492's Avatar
You never said if it's even turning over...
Have you checked to ensure you are getting a spark?
Are you getting fuel?
If you have those two it sure fire...
Old Feb 3, 2013 | 07:20 AM
casper510's Avatar
You're right, I left out some important pieces of the puzzle. The carb is getting fuel, I do have a spark. I have the back wheels off the ground and the wheels turn when I try to crank it, not sure if this thing should even do that. It sounds like it wants to start.
Thanks for your help.
Old Feb 3, 2013 | 09:25 AM
Jaster94's Avatar
3 things to do:
1. get a compression gauge and check compression. must be >90 psig.
2nd. , i know you said you've got spark, BUT please listen. how did you test for spark? replace the spark plug with an NGK. get a new one. i've seen that a spark plug will spark but won't spark under pressure-i'm still studying this phenomenon. but replacing the spark plug with a brand new one HAS fixed other quads with a similiar problem to what you're describing. c'mon, it's only $3! worth a try.
3rd, carb is getting fuel is fine, but is it making it through the jets? is your spark plug wet with gasoline when you crank? that should tell us a lot.
Old Feb 3, 2013 | 10:55 AM
casper510's Avatar
Sorry meant to say I don't have a spark.
Old Feb 3, 2013 | 11:36 AM
User492's Avatar
That's where I'd start...
Old Feb 4, 2013 | 11:14 AM
Jaster94's Avatar
ok, the brake switch is for cranking/turning over the engine. that's a safety interlock for the kids not to run over themselves when starting the quad.
as for the no spark condition:
try a new spark plug
test the kill switch on the left handlebar
check out the wiring on the keyed ignition switch and make sure that wiring is intact.
check the rear tether kill switch at the rear of the quad. it may be under the seat.
double check coil wire for frays/deficiencies
double check coil/cdi that pinched wires or any wire jacket deficiencies such as cracks, pinch points, or holes in the wire jacket/plastic coating.
report back.
Old Feb 4, 2013 | 11:18 AM
Jaster94's Avatar
when cranking, if you give it a shot of ether/starting fluid and it fires up and runs on that shot of fluid, then you have a gasoline delivery problem which leads to plugged jets. but if in the future you do this, be conservative, so you don't ruin the engine.
that is after you repair your no spark condition.
Old Feb 4, 2013 | 08:03 PM
casper510's Avatar
I'll give a a try and get back, that's again.
Old Feb 5, 2013 | 10:00 AM
LT80's Avatar
LT80 Expert
Once you get spark, I'm wondering about that chain. Could that be a timing chain and if so, it would effect the valve timing if incorrectly installed.
