1987 polaris trail boss rev limiter
Alright so when the rev limiter/black wire is plugged in it seems to be restricted from going to a higher rpm like its bogging, when I disconnect the black wire it will rev up like its supposed to, does this mean the rev limiter is bad? Thanks
Just leave it unplugged. Purpose of the limiter was to keep you from having full power in reverse unless you deliberately pushed the reverse over ride button,then you would have full power.Just a safety module that ended up shorting out most of the time. Some would die when you placed the machine in reverse,some would stay running in reverse if you held the over ride button in,some would start to limit in forward range also when the module failed.Just keep in mind that you have full power in reverse now without having to push the over ride.
Frisky2050
Apr 9, 2020 11:19 AM
