Tao tao won't strat
Old Jan 19, 2015 | 02:17 PM
clahue's Avatar
Default Tao tao won't strat
110cc Tao tao ran yesterday like a champ after new plug and gas. Air filter cleaned. Will turn over but does not start. Has spark. Kill switch not the issue. Used choke during start. Does not kick over to run. Any ideas. Plug seems wet with gas after I try to start.
Old Jan 19, 2015 | 03:22 PM
bdelancy's Avatar
does it have a teather on the back behind the seat? try pushing that in and see if that does it
Old Jan 22, 2015 | 08:53 AM
clahue's Avatar
It doesn't push in. I've messed around with it but no movement.
Old Jan 22, 2015 | 08:56 AM
bdelancy's Avatar
did you try unplugging it and pluging it back in i have had this issue with one of mine
bdelancy's Avatar
well if you have fire to the plug that eliminates this issue
Old Jan 22, 2015 | 08:58 AM
bdelancy's Avatar
have you shot starting fluid in the carb if it starts after you "prime" it with starting fluid or a shot of gas will work this means your issue is the carb
Old Jan 22, 2015 | 08:59 AM
clahue's Avatar
I have disconnected it and reconnected a few times but no change. Its a little tethered **** on the back grab bar that comes apart correct?
Old Jan 22, 2015 | 09:00 AM
bdelancy's Avatar
yes this is correct but if you are getting spark to the plug this isnt the issue
Old Jan 22, 2015 | 09:01 AM
bdelancy's Avatar
you may have a clogged primary jet in your carb not allowing the proper amount of fuel in or a stuck float allowing to much fuel in
bamax100
1) Engine problems..
13
Jul 22, 2014 12:49 PM
young#1
Aug 26, 2011 03:21 PM
wcrook1007
Oct 29, 2008 09:50 PM
MnTurboPaws
Oct 11, 2008 10:51 PM
jman01
Jun 7, 2007 05:14 PM
