Hard start lt 80
Old Jul 31, 2015 | 07:57 AM
ride26's Avatar
Default Hard start lt 80
Have done almost every thing I can think of to do. Cleaned the carb rebuilt the top end new plug. I started the motor broke motor in then putted around for lil bit. Then i shut it off and now it don't want to start for nothin. It is either getting to much oil or not enough fuel cause she smokes like a beast.
Old Jul 31, 2015 | 05:39 PM
nachop's Avatar
Start with the easiest first. Check the air filter to make sure it is clean and not over oiled. Based on what you posted, I am assuming that your LT80 is a 2-stroke. If it has an oil injector pump, mix the gas and oil manually to see if that helps. Also, check/replace your spark plug. It may be fouled.
Old Sep 26, 2015 | 07:47 AM
LT80's Avatar
LT80 Expert
Got spark? Spark plug cap broke?
Is the plug wet?
Plugged pipe?
Check the reed?
Old Oct 22, 2015 | 04:09 PM
DirtDevil101's Avatar
Compression test? I know you just rebuilt the top end, but there are only a handful of things to check:
1) Spark
2) Compresion
3) Fuel/air
Reed failure sounds plausable...could just be real flooded...ignition can just fail (mine did), so process of elimination is required...could be just fouled plug...
MikeyBoyesq
Nov 27, 2020 02:44 PM
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
chinkapin
Jul 14, 2016 06:58 AM
Ty Speece
Jul 2, 2015 04:59 PM
1000gade
May 27, 2015 12:37 PM
