Winch mount: Bolt or Weld
Old Aug 12, 2015 | 09:07 AM
MNatv89's Avatar
Default Winch mount: Bolt or Weld
For my atv, a 2002 Honda Recon I am trying to mount a winch and have a flat piece of steel, problem is I'm trying to figure out how to mount the mount for it. I planned to weld the mount to the frame, but someone else is telling me to drill a hole through the frame and bolt it through that. Which way would be the option to do?
Old Aug 12, 2015 | 09:26 AM
TLC's Avatar
TLC
I use U-bolts they also come with a winch package. Welding and drilling the frame both can weaken it.
Old Aug 12, 2015 | 09:37 AM
MNatv89's Avatar
Mine is just a flat piece of steel and the u bolts I found the hardware store seem to weak, 5/16 inch thick
Old Aug 12, 2015 | 09:48 AM
TLC's Avatar
TLC
Its not about size. It's about steel grade. Ask you hardware store for G7,G8 or G9 bolts.
A 5/8th G9 chain is much stronger the a larger 3/4 G2 chain.
Here is a grade chart that goes to G8.
https://www.boltdepot.com/fastener-i...ade-chart.aspx
Old Aug 12, 2015 | 06:00 PM
Scooter86's Avatar
Knows Old ATV Questions!
Don't drill your frame! Welding, done right, should actually strengthen it though. I too would just go with some nice u bolts and be done with it. A recon isn't that heavy, so as long as the plate is secure you should be fine.
Joe454
Nov 20, 2020 01:19 PM
Johnny Mac
Aug 15, 2019 03:13 PM
EIF
Apr 20, 2017 07:15 PM
cboler9
Sep 24, 2015 08:35 PM
chewy78
Sep 8, 2015 10:37 AM
