buyang 110 carb issues
Old Sep 27, 2015 | 04:57 PM
wrencher82's Avatar
Default buyang 110 carb issues
I bought a buyang 110 4 wheeler for 10$ that didn't run and needed a starter after I got it running I found out the carb needed cleaned, I cleaned it and noticed the float held fuel but I put it back together anyways. It would idle forever but wouldn't run very well unless it was choked quite a bit so I clened the carb made sure to drain and set the float right and sealed the float with some tank liner sealer as best I could, now it barely runs on full choke and it will not idle at all. Can anybody tell me what could be the problem, could the valves need adjusted? Any help would be appreciated
Old Sep 30, 2015 | 04:27 AM
Mechanicix's Avatar
Sounds like you still have some clogged holes in the carb. Those carbs are real tricky, when I do any carb I soak it in a puppet power or simple green solution, pine sol works also. And then I make sure all the tiny pin hole jets are cleared with a fine piece of wire.
Jmuddin284
Jan 19, 2026 07:16 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
tweeder
Jul 5, 2015 01:57 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
Mikea1978
Jul 4, 2015 12:37 PM
