Lt185 refuses to run
Old Feb 15, 2016 | 01:43 PM
Greasemonkey2067's Avatar
Default Lt185 refuses to run
I have a Suzuki Lt 185, I have no idea what year, but I cannot get it to start. It has great spark, great compression, and I cleaned out the carb. Even when I spray starting fluid into it, it will not even act like it wants to start. I have verified that the spark plug sparks at the right time, and I have adjusted the valves. I'm in need of some help.
Old Feb 17, 2016 | 09:44 AM
Zrock's Avatar
Super Quad Patrol
have you checked compression. low or now compression will give you no start or hard start issues
Old Feb 17, 2016 | 12:54 PM
It has great compression, I found that the problem was that the stator had to spin to fast to generate a spark. As of right now I'm converting it to a gm coil and module ignition
Wayne87
1) Engine problems..
Jan 25, 2020 10:59 AM
fishlips
Jan 22, 2016 03:57 AM
TaoTao110D
Jan 21, 2016 01:23 AM
Mattirons76
Jan 17, 2016 12:01 PM
