What oil for trans and Diffs? Polaris
The oil TLC pictured is an equivalent oil suitable for your gear case(transmission) only that some people use instead of Polaris AGL. You still need to use the Demand Drive Plus Hub Fluid for the front diff. Your front diff has the internal roller cage awd system. Your machine and the older hub activated awd systems(roller cages in the hubs) use the same Demand Drive fluid..
